> For the complete documentation index, see [llms.txt](https://docs.motus.org/en/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.motus.org/en/explore/data-dashboard.md).
# Data dashboard
Placeholder
GET https://docs.motus.org/en/explore/data-dashboard.md?ask=<question>&goal=<user_goal>
