Tag Deployment
Everything you need to know about deploying tags
Tag Management
This chapter pertains to tag deployment methods in the field. For information on the management of tag deployment metadata within the Motus system, see Tag Management.
Tag Deployment - Best Practices
Before you deploy your tags, consider the following:
Ensure local stations and any other stations you may rely on are active and working. Never assume that stations are working. Communicate with collaborators that manage stations from which you may expect detections. You may need to regularly check on stations yourself to confirm stations are functional.
Tag deployments are most effective when made in close proximity to an active station. Detections on a local station allow you to confirm your tags are working.
Be sure that tags are activated prior to their deployment using a receiver or an active Motus station.
Create a deployment with an anticipated start date prior to deployment. See Anticipated deployment date.
Plan to record the required metadata during deployment and update it as soon as you can following deployment. See Tag Metadata.
Always keep animal welfare at top of mind whenever you deploy tags. See note below:
Tag activation
Activation methods
Infrared
Activated using an infrared activator which must be purchased separately from Lotek. Lotek provides instructions on how to activate tags on their support pages.
Magnet
Comes shipped with a magnet which, once removed, causes the tag to start transmitting immediately. It can be reapplied to turn the tag off.
Activation methods
Sunlight
This tag transmits continuously as long as it has sufficient sunlight. HybridTag and BluBird may require charging in sunlight for a few hours to several days before it begins transmitting a signal.
Magnet
Remove the magnet from the tag. PowerTags should begin transmitting a signal immediately.
Cut
Cut off tab where indicated to activate.
How to tell when a tag is active
Regardless of the tag type, you always want to confirm each tag is active by looking for detections of your tag on a nearby receiver before you deploy it. This will need to be done using different ways depending on the tag type. See below for more details:
Methods for confirming a tag has been activatedHow to tag animals
As is the case for any new measurement technique for wild animals, researchers should always have in-person training on any tagging method before deploying tags on their own. In addition, tagging animals is hard and requires extensive experience handling birds of various sizes and species before learning how to tag.
Figure-8 Leg Loop Harness
Methods
Video
Adjustable Leg Harness
Methods
Researchers typically follow instructions published in:
However, these SOPs for Wood Thrushes and Snow Bunting have useful guide following the same principles:
Video
Backpack Harness
Glue on
Trimming tags
There are a number of researchers who opt to cut the antennas of tags when deploying on smaller animals. Basic antenna theory suggests it will decrease the effective power of the transmitter, but more testing is needed to determine the magnitude of this decrease when deployed on animals. Controlled tests have shown that OOK tags (166.380 MHz) will decrease in power with length, but are most effective when cut to specific lengths (harmonics of the nominal frequency). On the other hand, FSK tags (434 MHz) appear to decrease continuously with length, not showing better performance at specific lengths like OOK tags. These tag tests were not done on animals and will likely be different in real deployments.
That being said, if you're planning on trimming one of your Lotek tags, you should aim for one of these lengths to maximize the effect power:
166.380 MHz
18.0 cm, 15.0 cm, 12.9 cm, 11.3 cm, 10.0 cm, 9.0 cm, 8.2 cm, 7.5 cm, 6.9 cm, 6.4 cm, 6.0 cm, 5.6 cm
151.5 MHz
19.8 cm, 16.5 cm, 14.1 cm, 12.4 cm, 11 cm, 9.9 cm, 9 cm, 8.2 cm, 7.6 cm, 7.1 cm, 6.6 cm, 6.2 cm
150.1 MHz
20 cm, 16.6 cm, 14.3 cm, 12.5 cm, 11.1 cm, 10 cm, 9.1 cm, 8.3 cm, 7.7 cm, 7.1 cm, 6.7 cm, 6.2 cm
How to avoid tag aliasing
Aliasing can occur when multiple tags emit a signal at the same time. Sometimes these interacting signals can produce a pattern which match a different tag that is not actually present. This is due to the nature of how the unique tag ID is encoded in the signal. However, the parameters used to define these IDs are quite stringent, making aliasing only an issue in specific conditions.
Strategic tag deployment
To help mitigate aliasing, we recommend keeping numbers low at any given tagging site. This can be done by staggering deployments, either spatially or temporally. Most aliasing is caused by tags which have the same burst interval but a different Lotek ID. That means if you have more than one burst interval in your selection of tags, you can deploy more tags at any given site with a reduced risk of aliasing. However, do not deploy more than one tag with the same Lotek ID, even if they have different burst intervals!
Tag AliasingLast updated
